pc satellite apps dying out | Page 3 | SatelliteGuys.US
google it. its an app that will let you map any pc function to your remote.its not really programming but there will be a learning curve.
I did. Oh boy..... :( That doesn't look like the easiest thing to figure out..
I'll download it and look it over tonight though..
i didnt see what kind of remote your using. maybe sichbo would add support for it.
crackt out,.
Both of the pc tuners I have use the same identical remote so I just leave a remote in each room.
As far as I'm concerned, the pc sees the two tuners as one big tuner that tunes satellite and OTA. I can press the channel up and down buttons and go between the two seamlessly. :)
Here's the two tuner cards I have and the remote they use. Oh, and there is a little wire with an eye on it that plugs into the cards that I have to aim the remote at. The pc is in a cabinet so there are some wireless pyramids for that to get the remote signal down into the cabinet where the eye can see it.
Thanks! :)
hello guys , Altdvb diseqc 4*1 is not working on twinhan 1020a WDM drivers , but BDA 878 drivers are working on altdvb why? same WDM drivers are working on other DVB viewing applications dvbdream , schibo pvr mythater , TS reader all are working , any idea
low fec rate
Need help on 97 w!!!
