PBS - Yes/No ?? | SatelliteGuys.US
PBS - Yes/No ??
RT-Cat
"My person-well trained"
1,659
236
Cold, Cold,Michigan USA
I remember reading a discussion a time ago that small dish companies do not carry PBS. But when I use "Dishonline" and check the guide there I have listed KBME channel 3 - PBS and WCMV channel 27 - PBS. They are not in my subscribed list. So what goes here. Is PBS for only a few select cities??? :confused: I do not know those call signs or where they are located.
RT.
WCMV should be showing for you (channel 27). KBME is the Minot-Bismarck DMA PBS channel, so that one should not be showing for you. There have been a few reports from other people on the forums that they are getting locals from the wrong DMA showing in their DRA/DO.com guide.
:confused:
I live in the Washington DC DMA. When i scan for OTA channels I "see" some of the Baltimore DMA channels in addition to my DC locals. The Guide info for those Baltimore Channels appears, provided by dish. This is perfectly normal and Dish is doing nothing wrong.
Well,there it is! If you remember to include it in your favorites guide.(braindead moment).
RT.
I see what you mean. Really, with millions of subscribers and the USA+ for coverage area, a guide mixup of one or two channels when you have zillions of channels, is not too bad in my thoughts.
RT.
The problem was thought to have been corrected, but it's arising again. Working on a permanent fix, but logging out and back in (may take more than once) normally corrects the problem
VIP 922 Meltdown-DVR recovery?
Best way to get the NFL network and Redzone?
