(other than possible LOS issues)
That is my issue. I can't get 125 because my building is in the way
125W has more to offer.Just wondering... is there any benefit in getting PBS on 103 C-Band compared to 125 Ku (other than possible LOS issues)?
i'm not sure how much difference there is between the feed on 103 C-Band and LPB on 87W Ku. But definitely a lot easier to receive, plus never-ending cooking shows on CreateThat is my issue. I can't get 125 because my building is in the way![]()
i'm not sure how much difference there is between the feed on 103 C-Band and LPB on 87W Ku. But definitely a lot easier to receive, plus never-ending cooking shows on Create![]()
I would start working on a solution to obtain 125W if at all possible. You will be much, much happier!
I've got a couple of 1.2m behind a shop building that are positioned just far enough back from the building and just high enough that they look over the peak. One of those is fixed on 125W.Only solution I can think of would be to put the dish on the roof, and it makes me nervous- the GeoSat Pro 90cm dish has a lot of surface area and with the amount of wind we get here on the Plains, I'm not sure it would work
Indeed it does...just stay down wind of it.And does it really break wind?
Limited time offer
