PAS 1R | SatelliteGuys.US
PAS 1R
rene0228
15
Hi guys, every year i check for an update, PAS 1R which recvs channels from Honduras, Televicentro is on channel that is scrambled, have we found a way around it? is there another method as to how to get this channel, any help would very gladly be appreciated.
other than Canal 5 which is in PowerVu mode (which means only cable companies can sub to it) the other 3 channels in that group are free
TeleSistema Hondureño
Telecadena 7 y 4
Canal 48
Im sure Mr Iceberg that you are setup on this satellite, so 3 othe channels come in fine but canal 5 is scrambled? no way around it?
nope not set up on that satellite but Mike Kohl's list (global-cm.net) shows those 3 channels still free
no way to "get around" the other as you put it. Its scrambled and only cable companies can subscribe to it
powervu
PowerVu is a conditional access system for digital television developed by Scientific Atlanta.
It is used for professional broadcasting, notably by Retevision, Bloomberg Television, Discovery Channel, AFRTS and American Forces Network. It is also used by cable companies to prevent viewing by unauthorized viewers.
PowerVu has decoders that decode signals from certain satellites for cable distribution services. These decoders can also be used just like the FTA (Free-To-Air) satellite receivers if properly configured. PowerVu is considered very secure and has not been compromised since it uses a complicated system to authorize each PowerVu receiver and trace its history of ownership and usage. Most PowerVu users are professional cable or satellite companies, using the service and equipment for signal redistribution, because regular users cannot afford it.
getting rid of equipment...
how 2 convert a 1.2 m dish 2 c band??
