Panasonic Replay and Dish Network | SatelliteGuys.US
LeeJustin
2
I've finally had it with the poor quality of my cable signal and am looking into my satellite options. Right now the sticking point is my stand alone Replay, and I can't get a straight answer form either Directv or Dish.
Has ayone had any luck andor advise on whether I can use my Panasonic Replay with Standard Def Dish Network?
Thanks for any help yu can offer!
(I'm posting the same question in the Directv Forum)
Yes you can use a replay W/dish but it is a pain.
The receiver must be on at all times & most newer receivers turn themselves off after a periond of time & have the floating "press select to continue"which is what you will end up recording if you can not disable the auto shutdown.
So my advice would be get a 501, 508, or 721 receiver, built in dvr & no fee much more conveinent.
But if you want to try with your replay channel changing will be slow, & the receiver must remain on all the time or you will miss your recording.
Jordan
I've used a ReplayTV with a SD Dish receiver with no problem. I've gotten around the receiver turning off by itself by setting up an auto-tune channel at 4am. This will turn the receiver back on if it's gone off.
921 failing
WildBlue-1
