Outdoor Antenna Rotor | SatelliteGuys.US
bsr2002
SatelliteGuys Guru
123
South Texas
Looking for a Rotor I have found CM 9521A ($68.99) and Magnavox M61415 ($55.95). What are the difference between the two besides the price?
Thanks,
Ben :)
Go with the Channel Master (which RS also sells). I had it for a couple of years and it has been very good and steady. You can't go wrong with it.
The Magnavox is fine. I've had one for 7 years, and it still functions flawlessly. Both use the same three conductor cable.
Confused about UHF/VHF
Voom receivers will show fine tuning
