OTA Module | SatelliteGuys.US
OTA Module
pmalve
219
Does anyone know if Motorola makes a ota module that receives digital and analog channels? I wouldn't mind buying it. If not can you use a Dishnetwork module? I don't want to split my antenna cable before Voom receiver to hook up tv tuner as I lose signal and my weaker channels become unwatchable. It would be nice to have analog signals to use as a backup, then I could cancel my basic cable that I use for backup now. I helped my friend get his ota set up with a Directv tuner and it had this feature. Very nice to ba able to seamlessly change type of channels. You could watch Satellite local, analog local and digital local by just changing channel.
if there is such a module I want to know because I want to stay away from it. The last thing ill ever want is analog on my widescreen. LMAO
Sean Mota said:
If you use a +5db splitter (RS), there should not be any quality loss when you split both.
Sean, what is a +5db splitter? I went to RS online and just saw regular splitter and combiners. I have tried those and that is how I know I lost signal strength. If you could give me a RS catalog number I would greatly appreciate it. I hate giving cable company money I don't have to.
Mike
Actually, I just checked it is a 3.5 db two way splitter. I split the OTA signal to two receivers. I am sure you can do the same to voom and another analog ota tuner. I do not have a catalog number. I jus went to RS and picked one.
Actually, if the splitter isn't active, it's -3.5dbmv :). The ports may be labeled 3.5db, but that's the actual loss figure, which varies at different frequencies. The UHF's will probably lose more than 3.5dbmv at the high frequencies they utilize.
If you have a pretty decent signal to begin with, there should be little issue with using a good quality two-way splitter.
New to Voom - Antenna & Other Questions
Whatever happened to channel scanning update?
