Ota Antennas | SatelliteGuys.US
Ota Antennas
bbguy4701
18
Bakersfield, CA.
I HAD THE WINEGARD SENSAR III (3) AMPLIFIED BI-DIRECTIONAL INSTALLED WITH VOOM. MY ZIP IS 93311
THE TOWER COMPASS ORIENTATIONS AND MILES ALSO THE COLOR TYPE LIST IS FROM ANTENNA WEB.
MY QUSTION IS WITH THIS WINEGARD III WHAT IS THE BEST WAY TO AIM IT WING AROCSS THE SINGAL OR WINGS POINTING TO THE TOWERS IT SEEMS THE ON INSTALL I WOULD GET ABC CBS AND A LOT OF ANALOGS BUT NOT ABLE TO GET NBC. ALS0O COULD I HOOK UP 2 ANTENNAS ONE POINTING TO ONE TOWER AND ADD A BOW TIE AT THE OTHER TOWERS.
ONE ATHER THING IT LOOKS LIKE VOOMS HD IS NOT AS CLEAR HAS THE CABLE HD WAS LIKE THE TLC-HD MY SINGAL IS 97-99 ON THE VOOM DISH THANKS FOR YOUR HELP.
NBC 17.1 YELLOW 53* 22mi
CBS 29.1 LT GREEN 57* 35mi
ABC 10.1 BLUE 57* 30mI
An axis running through the "wings" should be perpendicular to the towers. In other words, the front side, which is opposite the mounting side, should be facing toward the towers. This is particularly important on UHF as the antenna tends to become somewhat directional at the higher frequencies (higher numbered channels). See http://www.solidsignal.com/manuals/WC-810.pdf for reception patterns. This is a good antenna at the distances you cite. If your reception is less than desirable, try moving the antenna to another location.
Some of the stations are not broadcasting a very stong signal.
I'd call the technicians and engineers at the station in question for an inquiry into why you could not receive it.
Alska and SHVERA
