Welcome to the forum, ACRadio.
Post a picture or two when you have a chance.
And thanks for the good advice.
Mine is mounted exactly 180 degrees opposite of their diagram. They just show a standardized diagram so they can have everyone on the same page as far as installation goes. As long as the feed is lined up and oriented properly and you know which LNB is which polarity it doesn't matter. But you go by their diagram...don't mind me...The instruction manual shows one C-Band LNB at 6:00 the other at 3:00 with the top Ku LNB at the 12:00 position with the other of course in the middle.
Your picture shows just the opposite for you installation.
Is there a reason why you positioned yours that way?
Thanks!
That's ok by me!Mine is mounted exactly 180 degrees opposite of their diagram. They just show a standardized diagram so they can have everyone on the same page as far as installation goes. As long as the feed is lined up and oriented properly and you know which LNB is which polarity it doesn't matter. But you go by their diagram...don't mind me...
Hi Rob,I just ordered a dual C band and dual ku band feedhorn with two Norsat 8000 c-band lnb's and two Norsat Ku lnbs.
This is I guess what you call an "orthomode" feed horn (no servo)
I am planning on running a multi-switch and going "Servo-LESS"
what kind of multi-switch do I need to do this.
I could run two seperate cheap DBS multiswitches (one dedicated to each band) or is their one multiswitch that will perform the whole job?
ACRadio, I've got a quick question about your farm...
Do you have all the dish grounds bonded together along with the equipment grounds?
I've been over and over trying to determine the best approach to grounding...
I have 8 & 10 foot mesh dishes about 25 feet apart and about 200 feet from the service ground.
I've heard the dishes should be bonded together with #6 running all the way back to the service ground...
Just curious about your (as well as everybody else's) thoughts on this...
Hi Rob,
Is the "orthomode" it's own name brand or is it part of the Chaparral that you were getting like the Bullseye?
Thanks,
Tom
If I put a power inserter in the line and bumped the voltage up to 18, will that increase the Signal Quality I am already getting on the Vertical side?
Ok, I have a question about the voltage as stated above needing to be 17 or 18V to get the best signal on the Vertical side of the old style C-Band LNBs.
I am not doubting anyone's word, but just have a question.
I just put the meter on my Pansat 3500 which is currently running a used Cal-Amp 25K LNB that I picked up somewhere along the way.
It is clearly putting out 13.7 Volts on the Vertical channels and 18.9 Volts on the Horizontal channels.
I'm getting some pretty darn good Signal Quality for just 13.7V being fed to the LNB.
It would be dependant on the make and model of the LNB. It all depends on how the manufacturers circuitry behaves with a reduced voltage. What will work with one may not work with another. To know for sure the LNB manufacturer may be able to tell you or try a power inserter to find out for yourself. Just make sure to get a power inserter for the proper voltage for the LNB. As specified on the Norsat web site, their LNB's require +15v to +24v. The LNB manufacturer should be able to suggest a power inserter to use or a google search such as
DC Block Power Inserter with AC Adapter For LNB Power Insertion
Amazon.com: Dual LNB Power Inserter: Electronics
f you tell the receiver the vertical channels are horizontal, then the receiver will put out 18.9v for all the vertical channels. Then use one of your other receivers to run the servo for the polarity, or physically rotate your LNB 90 deg to test this out. This should be able to tell you if the voltage is a factor or not.
My quality readings were fine if compared to other quality readings and would have basically been acceptable. But after I took a look at the hard data it was an easy decision to install the power inserter. I use the one at the Amazon.com link in Larry's post above. I will spend 30 bucks for an extra db C/N any day...and here's why...I'm getting some pretty darn good Signal Quality for just 13.7V being fed to the LNB.
Thanks ACRadio.When looking for that HD sporting event I have seen a couple of times that the signal was close to the ragged edge...I'm glad I had that extra db. I'm using a slightly undersized dish also so I need every tenth I can get...
Limited time offer
