Latest firmware history
Updates for --> SW V21054
--> fixed "slow, freezing, and hang-up" matters
--> UTF-8 Unicode Support add.
--> RSS News function add.
--> Internet Radio+ Screen Saver support add. (activ after 5min.)
--> Weather Forecast function improved & extended :
--> New OSD Design for Weather Forecast
--> Refres--> SW V21052
--> Samba Version upgrade 3.0
--> Avaiable to Add Internet Radio+ URL by user : Added
--> Available to move Favorite Channel Group : Supported
--> 3G modem Driver data (BandRich BandLuxe C330 Series) : Updated
--> Display Genres in EPG : Supported
--> Nachrichten/Akuelles, Show/Spielshow, Sport, Kinder/Jugendprogramme
--> Kunst/Kultur, Soziales/Politik/Wirtschaft, Ausbildung/Wissenschaft/Fakten
--> Musik/Tanz/Balett, Freizeit/Hobby, Spielfilm/Drama, Originalsprache
--> Supporting Cyrilic in Internet TV & DLNA : Supported
--> TP list (Eutelsat 36A, 36B) : Updated
--> Google map Icon in shortcut : Added
--> WebZeal Hang on in specific website (.sk) : Solved
--> HDMI Compatibility problem with different TV set Solved
--> Philips LCD TV 32PFL5405H, other SAMSUNG models
--> New functions add for up / down (cursor) key :
--> Menü - Display Settings : Up / Down key
--> Service Change : one by one ch zap (All Services)
--> Programmliste : Quick Service list for 15 Ch. incl. EPG Info.
--> HD Service Change : one by one zap (HD Services)
--> SW V21049h Data function add. (RECALL Button)
--> Weather Forecast: Country and City list add. (RED Button)
--> DVB-C Cable Channel Search improved
--> JPEG Viewer function improved
--> Hangup in Servicelist fix.
--> Page up & down bug by playlist fix.
--> Astra 19,2E Transponderlist upgrade
--> Memory leak. problem fix.
--> Progress bar add. for User Data Format function
--> Menu - System Tools - Storage Manager :
--> Current Device : User .. pls. press OK for start format
--> New OSD Language add. : hebrew
--> PIP Service list sorting function add. (Red Button)
--> Diverse minor bugs fixed
I think its combined history list from 2.10.49 2.10.52
Searched other sites without success. On one site, they claim their firmware and lists update by downloading via the factory web server. Could be false advertising info too. Still working on U.S. channels. Seems most U.S. streams use unsupported codecs and less rtmp. For U.S. need to request factory incorporates more capabilities than rtmp.Does anyone have the internet stream file from the amiko box? I would say the same streams will work, just need to compile them.
What is DVB-C ? Do you hook your cable tv to this too?
Still waiting for the basic blind scan to be corrected.![]()
This is laughable!CNN shortcut added
This is laughable!
FIX BLIND SCAN THAT'S ALL THE USERS WANT!
if the receiver only has one sat input how can it record 3 things at once (even on same transponder)?being able to simultaneously record 3 channels at once while watching another
Limited time offer
