Only half of programming is being recorded on my 622... | SatelliteGuys.US
aviation76
83
10
DFW, TX
Hello,
Recently, we have been noticing that only half of a program is being recorded on our VIP 622. For example, if I record a 1-hr show then I only obtain 20-30 minutes of that show. This does not happen frequently but enough to be an annoyance. This happens regardless the time of day...so my 3 AM update period is no factor. Also there is not any schedule conflicts with other recorded shows nor is there anyone manually stopping the recordings. I have software version L6.16 on the unit.
Any thoughts?
Thanks!
Nope, the DVR has over 100 hours available diskspace for SD programming and over 20 hrs available for HD programming. I have a Panasonic TH58PZ800U plasma. Just curious, what does the TV brand have anything to do with the way the DVR records?
Anyway, I rebooted the DVR and I will report back the results.
Hello,
Any thoughts?
Thanks!
I have had this happen maybe twice, i just put it down to somebody cancelling the recording. I have had no powercuts, my pc would have rebooted that im folding on. i cant see any pattern as it's happening infrequently. i have 2 622's and for the "key" programs irecord on both, so will get it on one if i dont on the other. Cant tell you the software versions at this point, so no help there, but you are not alone !
As you say annoying but not quite enough for me to spend any real time looking into. Sorry
It's February, is it time to switch?
How to Reset Dish 311?
