one newbie question! | SatelliteGuys.US
megadeth_rocks
16
Hi, one newbie question here, I use the dishpointer page to aim my dish to Intelsat 805 in 55.5W and the page tell me adjust the elevation to 23 grades, this elevation is correct for C band dishes or only for KU dishes? is the same elevation on the 2 types of dishes? thanks!
The elevation is the same for C or Ku band.
If you are using an offset dish the angle of the reflector will be different than a prime focus dish...but both dishes are "looking" at a satellite that is the same elevation above the horizon.
Cband Dish Modified for WiFi
Going C-Band ... Have a question!
