B budhead151 SatelliteGuys Family Original poster Jan 4, 2007 94 3 Mar 7, 2014 #1 Now that AAD is gone do I need that dish any more? I have AT250 HD dish and the coax from the 119 goes to it. Can I disconnect it? It is the grey coax with the tape on it.
Tampa8 Supporting Founder - I'll stand up and say so Pub Member / Supporter Lifetime Supporter Sep 8, 2003 18,298 8,140 Tampa/Eastern Ct Mar 7, 2014 #2 You didn't say so I will assume you are on the EA. If so, unless you want some backup you can disconnect it. If on the WA leave it.
B budhead151 SatelliteGuys Family Original poster Jan 4, 2007 94 3 Mar 7, 2014 #3 Tampa8 said: You didn't say so I will assume you are on the EA. If so, unless you want some backup you can disconnect it. If on the WA leave it. Click to expand... Sorry, Central New York, zip 13340 What about the coax that is not connected to the grounding block that goes up to the HD dish?
navychop - Pub Member / Supporter Lifetime Supporter Jul 20, 2005 62,123 30,284 Northern VA Mar 7, 2014 #4 I'd leave it connected either way.
Bobby Publican Supporting Founder Lifetime Supporter Sep 7, 2003 72,741 29,874 Rohnert Park, CA Mar 7, 2014 #5 It ain't broke, why fix it....
