Old AAD Dish | SatelliteGuys.US
Old AAD Dish
budhead151
94
3
Now that AAD is gone do I need that dish any more? I have AT250 HD dish and the coax from the 119 goes to it. Can I disconnect it? It is the grey coax with the tape on it. 20140227_133547-1.jpg
You didn't say so I will assume you are on the EA. If so, unless you want some backup you can disconnect it. If on the WA leave it.
Sorry, Central New York, zip 13340 What about the coax that is not connected to the grounding block that goes up to the HD dish?
322 receiver problems
Sound drop on recordings
