Otherwise what would they do with all the returns they will probably see?
The chips aren't socketed (chips have been surface mounted for a long time now) so that's not a cost effective option as Hall remarks.Is it possible that DISH will remanufacture the returned Joey 1.0 with a faster chip and then put them back in use?
What does socketed and surface mounted mean?The chips aren't socketed (chips have been surface mounted for a long time now) so that's not a cost effective option as Hall remarks.
Socketed = for lack of a better term, means "removable". Surface-mounted = soldered in place (typically).What does socketed and surface mounted mean?
OK, thanks.Socketed = for lack of a better term, means "removable". Surface-mounted = soldered in place (typically).
The 4K Joey will retail for $149. When singing up as a new customer the 4K Joey will require a $50 upfront fee. It will also cost $50 for existing customer to upgrade to it.
No.I have a "Super Joey." Is this the same thing as the Joey 2?
Looking like the "free if qualified" upgrade isn't going to be "free" since many wanting the H3 will also want the 4k Joey. Got everybody's hopes up when they said the word "free", we all knew better. Just like the H2 it will probably be a minimum $100-$200 upgrade for most.The 4K Joey will retail for $149. When singing up as a new customer the 4K Joey will require a $50 upfront fee. It will also cost $50 for existing customer to upgrade to it.
Free for someone who doesn't already have a Hopper system.Looking like the "free if qualified" upgrade isn't going to be "free" since many wanting the H3 will also want the 4k Joey. Got everybody's hopes up when they said the word "free", we all knew better. Just like the H2 it will probably be a minimum $100-$200 upgrade for most.
Not a problem for single tv homes. Should be free for usLooking like the "free if qualified" upgrade isn't going to be "free" since many wanting the H3 will also want the 4k Joey. Got everybody's hopes up when they said the word "free", we all knew better. Just like the H2 it will probably be a minimum $100-$200 upgrade for most.
You have the 2nd fastest Joey available, if I'm not mistaken. In order of performance, it should look like this:I have a "Super Joey." Is this the same thing as the Joey 2?
The Super Joey is NOT compatible with the Hopper 3. If you think about it, it would put you over the current 16 tuner limit of the DPH LNB.I have a "Super Joey." Is this the same thing as the Joey 2?
It seems odd that the Virtual Joey isn't compatible. Probably the same reason a Joey 1 won't work with a CAT5 connection.The Hopper 3 is not compatible with the Joey 1, Virtual Joey or Super Joey.
Again not accurate. The Super Joey is not compatable with the DP ZLNB technology which the Hybrid LNB uses.The Super Joey is NOT compatible with the Hopper 3. If you think about it, it would put you over the current 16 tuner limit of the DPH LNB.
Limited time offer
