Not receiving all channels from 119 - NEED TO CORRECT THIS TODAY | SatelliteGuys.US
JINXR
43
Not receiving all channels from 119 - FIGURED IT OUT. WATER IN CENTER LNB!!
Last week, I stopped getting certain channels from 119. It starts searching for the different modules (I think?). I still get some channels from 119 though. I took a look at the signal and it is very weak. 110 and 129 look good though :confused:
What should I do? I really need to get this fixed today.
UPDATE:
Figured it out. The middle LNB was over half full of water. I have the Super dish (1000.2). It looks like all three are leaking though. I was able to pry up the white translucent cover a little and drain enough that my signal went from 8 to 41 :eek:
So how can I fix this? Will I need new LNB's or can I somehow pop those off? They're really tight and I actually deformed the edge of the center one trying to pop it off. I figure if I can get it off, then I can seal them off with a bead of silicone.
What equipment are you using with Dish??
QAM Help
fox-sports north wisconsin?
