Not getting all SC HD channels, HELP! | SatelliteGuys.US
localnet
16
I just upgraded to the DSR530 from the old 500. I also installed a new bigger 70? SC dish.
My signal strength is in the 90's and my db's are around 12 on all channels. I get the same readings on the channels I am not receiving.
I get some of the HD channels, but not my east and west HD networks or the two CBC channels, which I get fine in SD.
I get WGN HD, TMN HD, SNET HD, DIS HD, A&E HD, SHOW HD, and HDNET. And I have the everything you can get package, including the extra HD channels.
I have tried the soft reset a number of times to no avail. I have left the 530 off at night for downloads. This problem has gone on for 3 days now.
Any help would be appreciated.
Mike
You mentioned that you changed dishes. Did you go from a stacked (beer can shaped LNBFs) to a stacked dish (built in quad LNBFs)? If you did your maps need to be changed - SC will have to rehit with proper code for your LNBF type.
Problem is solved, it was on SC end. They neglected to turn on ALL of my HD channels. Me and Cathy at tvm got it all straightened out today.
Where do cable companies get TSN feed?
How can I get the Blue Jays on StarChoice (which package)?
