no output voltage? | SatelliteGuys.US
no output voltage?
airhead13
18
have swm dish with 4 rcv.moved one to camper using 18" dish and now this std rcv does not work at all.has no output voltage? I guess by using a swm splitter and power supply after I moved std rcv it will not have any output voltage .is there a way I can reset this std rcv and make it work on 18" dish?
If you can get into the menus, go into Repeat Sat Settings, thats where you can make those changes.
But your right, it's expecting to see the 21v from the PI that is not there, once you get the changes made, it will send the voltage from the recvr.
Thanks jimbo,I thought there was a way to change back.will give it a try tommorow!
have 1 more ?. do I leave sat cable connected from swm splitter or disconnect b-4 change settings so it want be looking for 21 v.or do I just unplug power supply and leave cable connected?
It's been a LONG time since I last came across this, thats a good question...
I think I would try removing the SWM PI first and see if it works, I don't know that the splitter would have any effect or not.
The PI is where the LNB is currently getting the voltage, without it, it should revert back to recvr power.
Is there a way to turn off TVMail?
DIRECTV to Introduce NOMAD tomorrow
