Hmmm. Is there a DVR that sends signals to a rotor to reaim an OTA antenna? So when you DVR different channels with antennas in different directions, it tells the rotor the new aim point?
UAALS?
You hit the nail right on the head... 1,5,9,13,17,21,25,29 transferred yesterday. 3,7,11,15,19,23,27,31 transfer tonight.
Start checking around midnight your time or a little there after.
Is there any way to get the Eastern Arc Dish in Maine, to be able to pick up all my SD Channels in MPEG 4 instead of MPEG 2. Why don;t they do Eastern Arc installs yet in Maine? I live in Bar Harbor, Maine.
Now what happens to the older echostar sat up there? Will they move it to help out 61.5 sat? I know they are having some problems with their transponders.
If there is enough gas in the tank I would think it would head over to 148.
The FCC isn't going to Echostar get 148 without a bird there indefinitely.
Straight from the horse's mouth
Echostar gets right to obtain all 32 transponders effective Jan 1, 2010
http://licensing.fcc.gov/ibfsweb/ib.page.FetchAttachment?attachment_key=-182033
The movement of E-6 is still unknown which is puzzling. In regards to 148 W, Dish could build a satellite with just spotbeams to Alaska and Hawaii. This should be a cheaper satellite because of the need for limited coverage area. It also may not need as much power becuase it will only have two spotbeams but if it could provide greater power than could allow for the use of smaller dishes for customers in those states.
My guess of what is going to happen is as DirecTV vacates a number of TPs at 72.5 W, Dish will get use of them but DirecTV is not going to vacate them all by Janyuary 1, 2010 so there will be a phase in of usage. I would expect Dish to have use of 20 - 24 TPs on January 1, 2010 and probable as many as 28 by mid 2010. Dish may have use of all 32 TPs by the beginning of 2011 but it might be until mid 2011.
I think it will be sooner. Directv 12 goes up in December and will be taking over spot beam service for the defective Directv 10. This eliminates the capacity bottleneck that required the use of the 72W slot.
"As the Commission is aware, DIRECTV 10 suffered an anomaly that has limited the capacity available in certain local markets.See, e.g., Letter from William M. Wiltshire to Marlene H. Dortch, CS Docket Nos. 98-120 and 00-96 and MB Docket No. 07-91, at 6 (Mar. 10, 2008); Letter from William M.Wiltshire to Marlene H. Dortch, CS Docket Nos. 98-120 and 00-96 and MB Docket No. 07-91, at 1-2 (Feb. 13, 2008)"
I would think that w. the new D* sat up in Dec and the FCC giving consent to E* to use the tps at 72.5(.7) then it will happen by the 1st of 2010. If D* isn't off the 72.5 sat by then they would be in violation of this new document for changing who has the rights to transmit from that location.
Dish applying for and receiving approval from the FCC to use all 32 TPs is only as good as they have a lease agreement with Bell TV/Telesat. This does not prevent DirecTV from utilizing the TPs for which they have a lease agreement with Bell TV/Telesat. The Dish application only requests FCC approval for when their lease agreement with Bell TV/Telesat allows them to use all 32 TPs which I believe is related to when DirecTV gives up there lease. I am speculating that DirecTV will probable not due this all at once but will phase in.
In regards to the DirecTV-12 launch, even if it goes in December of 2009, it will be a few months before it is operational based on the time it took to test DirecTV-11. DirecTV-12 also has a "reverse DBS" capability which I am sure will be tested as well which may increase this testing time. In addition, for the customers in the markets at 72.5 W that will be moved to DirecTV-12, they need to have their equipment, both dishes and receivers upgraded which also adds to the time.
Limited time offer
