new sub needs help with HD-RSN | SatelliteGuys.US
thomas_d92
47
Exeter,ca.
I cannot find my HD RSN in the guide. I receive FSN WEST and FSN Prime Ticket. If there is any HD on theses channels will it show up on 94,93 and 98?
It should show up on 94 or 95, but they don't always show your game even if it is in HD. They don't have enough room to show all of them right now.
If it is a full time channel, and you have either the H20 or HR20, and a 5 lnb dish, you will get it at the same number as the sd channel.
*If* they are available in HD from DirecTV (which they are) they will be in MPEG4 and will be found on channel 96 or 97. You will need the 5 LNB dish and either an H20 or HR20 to receive it.
Channels 94 and 95 are only "best of" channels and are mainly used for MLB Extra Innings right now.
Put your zipcode in here to see if they are available in your area: Local Regional Sports Network Information
Note that by the end of Sept the HD RSNs will go on the national beams and will be available to people exactly like the SD versions are today.
94 and 95 is where my local RSN Fox Sports Cincinnati shows their HD games. I don't have MLBEI either.
Expanding capacity of HR20
AT9 versus Slimline
