Disc 2 Metallica Cuts & Extras...Thanks John. I just ordered the Rock and Roll Hall of Fame Blu this weekend, looking forward to that.
Ok, here are the new additions to the family. I was able to listen to some Klipsch Reference, and got some friendly advice from teachsac. I started figuring, why not enjoy them now, why wait for the house build
Will get the surrounds at a later date.
My two fronts:
Klipsch RB-81 II
SPECIFICATIONS
- BUILT FROM: 2010
- DEPTH: 12.3" (31.2cm) with grille
- ENCLOSURE TYPE: Bass-reflex via front-firing port
- FINISHES: Black Ash & Cherry woodgrain vinyl
- FREQUENCY RESPONSE: 44Hz-24KHz ± 3dB
- HEIGHT: 19" (48.4cm)
- HIGH FREQUENCY CROSSOVER: 1400Hz
- HIGH FREQUENCY DRIVER: 1" (2.54cm) Titanium diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
- INPUTS: Dual binding posts / bi-wire / bi-amp
- LOW FREQUENCY DRIVER: 8" (20.3cm) Cerametallic cone woofer
- MOUNTING: Dual bottom mount 1/4"-20 threaded inserts
- NOMINAL IMPEDANCE: 8 ohms compatible
- POWER HANDLING: 150W RMS / 600W Peak
- SENSITIVITY: 97dB @ 2.83V / 1m
- WEIGHT: 27.5lbs (12.5kg)
- WIDTH: 9.3" (23.5cm)
My center:
Klipsch RC-62 II
SPECIFICATIONS
- BUILT FROM: 2010
- DEPTH: 12.8" (32.4cm) with grille
- ENCLOSURE TYPE: Bass-reflex via dual front-firing ports
- FREQUENCY RESPONSE: 57Hz-24KHz ± 3dB
- HEIGHT: 8" (20.3cm)
- HIGH FREQUENCY CROSSOVER: 1500Hz
- INPUTS: Single binding posts
- LOW FREQUENCY DRIVER: Dual 6.5" (16.5cm) Cerametallic cone woofers
- MOUNTING: Uptilt and Downtilt feet
- SENSITIVITY: 98dB @ 2.83V / 1m
- WEIGHT: 30.4lbs (13.8kg)
- WIDTH: 23.5" (59.7cm)
My rears (to be ordered when the room is constructed):
Klipsch RC-62 II
SPECIFICATIONS
- BUILT FROM: 2010
- DEPTH: 9.2" (23.4cm)
- ENCLOSURE TYPE: Bass-reflex via quad side-firing ports
- FINISH: Matte Black vinyl
- FREQUENCY RESPONSE: 50Hz-24KHz ± 3dB
- HEIGHT: 15" (38.1cm)
- HIGH FREQUENCY CROSSOVER: 1300Hz
- HIGH FREQUENCY DRIVER: Dual 1" (2.54cm) Titanium diaphragm compression drivers mated to 90° x 60° square Tractrix® Horns
- MOUNTING: Keyhole bracket and quad 1/4"-20 threaded inserts
- NOMINAL IMPEDANCE: 8 Ohms compatible
- WEIGHT: 22.7lbs (10.3kg)
- WIDTH: 16.3" (41.5cm)
I stuck with bookshelfs, but they do have 8" woofers![]()
i love the sound of vintage klipschs. i have a klipsch center speaker which is only a few years old. but i'm thinking about upgrading to b&w's and using my jbl studio speakers as rears!
Man, spreading these puppies out really worked nicely, and I have them about 5" off the wall, must be helping the bass too. Instead of being able to pick out the sub with the Def Tech's, it's like bass is coming from all around both sides of the tv man, I love it. Like a freaking bass wall.
Limited time offer
