New SMart card problems??? | SatelliteGuys.US
tman1991
SatelliteGuys Guru
137
I got my 3, 622, 625, 508/510 (not sure which off hand).
The 508/510 was painless.
The other 2 are have been in download program guide for an hour! I reset both and they are back at download program guide..
My VIP622 took forever to download the program guide information, and the receiver never did regain all of the programming. Great job, Dish. You screwed up my receiver with your little smart card "upgrade." I have to switch them out because my receiver isn't authorizing the card I guess. Good stuff, I tell you.
i pulled the cards from the 625 and 622 and put it back in. The 625 took about 5-10 minutes and worked the 2nd time.
The 622.. well it redid its thing, found the programming guide download then came up with an error - smart card inserted.
So pulled the card again and finally on the 3rd try it worked.!
Overall, for waht should have been 10 minutes it was about 2 1/2 hours.
After 2 hours, guide info was still loading. Reset and all's well.
No ION 280 on TV2
Dishs Claim of 150 HD channels by end of Year.
