I'm glad to see some re-allocation of the HBO/CineMax into the StarzEncore channels, finally!![]()
Dish never carried HD feeds of all of the Cinemax channels they had (when they still had Cinemax) so that may be a long wait.now if they would just get the rest of them in HD
i totallly agree with you on that my friendnow if they would just get the rest of them in HD
But...but...it's 2020!Dish never carried HD feeds of all of the Cinemax channels they had (when they still had Cinemax) so that may be a long wait.
The answer to that is yes. There were many programs in B&W in the middle 60s. There were not two different broadcasts either, they both lived on the same channel/frequency. Same signal, just depending on whether you had a color TV or B&W is what you saw.It's 2020 HD is pretty well mainstream by now, I think it's high time ALL TV channels should broadcast in HD at least.
Does anybody remember when TV Channels transitioned from B&W to Color? I remember B&W Channels when I was about 5 or 6
then Color TV started happening, but I don't know if you bought a Color TV were some channels still broadcasting in B&W?
If we are talking about OTA broadcast TV, then broadcasting in SD allows stations to multi-cast more subchannels than they would be able to carry otherwise. I would rather have my local OTA station carry BUZZR in SD, than not be able to carry it at all.It's 2020 HD is pretty well mainstream by now, I think it's high time ALL TV channels should broadcast in HD at least.
The boxes for TV antennas at Radio Shack always said"Color TV antenna" just so people would know it wasn't just for B&W.It's 2020 HD is pretty well mainstream by now, I think it's high time ALL TV channels should broadcast in HD at least.
Naw, it was more like "if you want color TV you need this color TV antenna!" We see the same thing today with HD antennas and recently the indoor 4K antenna. Some, if not many, people will think that they need to go buy a new antenna to receive these OTA services. Of course we know that you can receive all of these services, 4K when it gets here, with the same antenna you have always used. Just to touch the base, because of the ongoing repack of channels you may need a new antenna if the one you have is UHF only and your local area is moving to some VHF channels.The boxes for TV antennas at Radio Shack always said"Color TV antenna" just so people would know it wasn't just for B&W.
Plus, especially in the early days, B&W was sharper, and more stable.
And of course, those were the only type of antenna available. So, people would buy one and think "Oh great, now I need to go buy a new color TV to go with it, if I want to be able to watch anything."The boxes for TV antennas at Radio Shack always said"Color TV antenna" just so people would know it wasn't just for B&W.
Let's not forget that the reason many people were able to get by with UHF-only antennas was because, in the digital transition, many stations that had previously been on VHF frequencies chose to move to UHF. So, viewers may have been able to get all of the major networks with a VHF-only antenna before the digital transition, and then found out that they needed a UHF antenna to get the new digital signals. If they happened to switch to a UHF-only antenna, they will now once again need a new antenna (or go back to using their old VHF antenna, if they still have it) now that some stations are being forced to repack back into the VHF range. No wonder some, if not many, people think that they need to go buy a new antenna each time we go through one of these transitions.Naw, it was more like "if you want color TV you need this color TV antenna!" We see the same thing today with HD antennas and recently the indoor 4K antenna. Some, if not many, people will think that they need to go buy a new antenna to receive these OTA services. Of course we know that you can receive all of these services, 4K when it gets here, with the same antenna you have always used. Just to touch the base, because of the ongoing repack of channels you may need a new antenna if the one you have is UHF only and your local area is moving to some VHF channels.
That was always a nice benefit in the analog days, if you lived in an area without reliable OTA reception, much like myself. When the signal was not stable enough to produce a color picture, I could at least still watch a snowy black-and-white picture. The only modern equivalent to that would be with streaming. If your connection is not reliable enough to deliver a HD picture, then it will buffer, and maybe switch resolution to SD to use less bandwidth....
Many programs were still broadcast in B&W for years after color TV came out.
It was a lot more expensive to produce a color program than B&W, and many wanted there to be more color sets in people's homes before making the investment.
Limited time offer
