We have locked and displayed a 4:2:2 signal with the Fortec Star Passion. The firmware update is scheduled to arrive in the next few days. Should have a review available soon ...... ANTICIPATION ........
Only they can answer that, but 4:2:2 HD is very rare, so I'll doubt it. I would like to know if it was a 4:2:2 HD feed, was the green bar visible at the bottom of the screen, as you see with a Qualitv.Was that a 4:2:2 HD signal?
On Ku... PBS HD and feeds.
On C Band there are a couple such as Outdoor channel / Movie Central HD / another PBS. There are of course Feeds on C-band as well.
I may have dorked the semantics, but remote news casts, sports uplinks, basically stuff that is only up as long as whatever event they are covering is.Another dumb ?? but what are "Feeds"?
Arm, leg.........maybe more!! :haha<snip>
And how much is going to cost to buy this hot new baby!![]()
Can you check if it down-converts the HD to the SD outputs? I would assume it does, but by the same loc you'd think it would convert AC3 audio to 2ch stereo for SD outputs too. Can you check those two?
#1 - While displaying an HD channel, say PBS HD, see if it displays a SD down convert on the S-video / composite connections. If so there options to format it (letterbox, squeeze, etc).
#2 - When locked on a channel with AC3 audio (I believe PBS HD also has AC3 audio) do you get sound via the red/white RCA connections?
Thanks!
I can't wait to see the result of this hot new receiver!!:
But I am wondering will it convert PAL video to NTSC regardless of 4:2:0 or 4:2:2 SD or HDTV video fomat?
Is PBS HD broadcast in 4.2.2 HD?I don't think it is.Yes, 4:2:2 HD (PBS and some network feeds).... Still awaiting the test firmware.PATIENTLY ...... YEAH... Right!
Limited time offer
