New Dish HD Equipment - what else do I need. | SatelliteGuys.US
ride525
442
SF Bay Area, California
Right now I have Dish 500 system with 4900 receiver.
1. If I get a 6000 receiver, and just replace the 4900 is there anything extra I need to install?
2. How about if I install the 6000 receiver, and keep the 4900 as a second receiver, anything extra needed?
3. Anything extra needed if I get 811 and just replace the 4900?
4. How about if I add 811 and use 4900 as second receiver?
5. When I add SuperDish, will I need to add anything to the above?
Thanks for your help,
Jeff
Not really, unless you want HBO HD or SHOWTIME HD before you get superdish
Not knowing what switch/lnb setup you have on your 500 not sure other than an additional coax from dish for second receiver
same answer as #1
same answer as #2
No the superdish will replace your dish 500
How does your HD compare to DVD ?
Novice Dish 6000 Installation Question
