New Dish Customer - Need To Add Tuners | SatelliteGuys.US
BigBird0000
3
3
las vegas
I just got Dish installed. The equipment listed is:
Slimline HB1000.2
2 Joey 2.0
1 Hopper Sling
However, There are only 3 tuners -- I need more than that to record shows.
Can I upgrade the Hopper to a Hopper 3 to get more tuners... same wiring?
Can I do this as a new customer (I rent the equipment right now)
Slimline HB1000.2
2 Joey 2.0
1 Hopper Sling
You really should have done your homework before installation. The Hopper 3 has 16 tuners. There will be some wiring differences between the Hopper with Sling and the Hopper 3. The Hopper 3 needs to be in a hybrid environment so will need either a hybrid LNB or have a hybrid 42 switch installed. You might ask DISH if you can have an upgrade to the Hopper 3 because the HWS they just installed doesn't meet your criteria.
Slimline HB1000.2
2 Joey 2.0
1 Hopper Sling
When was the install?
It's the same wiring and maybe even the same LNB on the dish.
Contact whoever you ordered it from, which was hopefully a local retailer. If it was Dish directly then contact them. There will probably be some kind of upgrade fee depending on the account.
Almost all Hopper installs include a Hybrid LNB and a Hub these days. :)
Since he has a slimline LNB< he's already Hybrid
Yeah, I was looking at the options, and my wife placed the order with them without me telling her
what we needed. I will try calling them. I wish my wife asked first, but I am surprised that they would only have 3 tuners, not allowing any recordings if everyone has their TV on. We screwed up.
Reactions: TheKrell
The Hopper 2 that you got was probably the no cost option. A Hopper 3 probably had a $50 or $100 extra fee.
Just call DISH and if you get a male csr, just blame it on the non-techie wife. They'll understand and believe you.
Or, if you get a female csr, just take total blame for the screwup and explain that your wife is really pissed at you and you have to come up with a solution to keep peace in the house. They'll believe you and sympathize.
But, if you get one of those confused types, just beg and cry a lot....................or hang up.
Upgrade to Hopper?
The Blaze is history
