New azbox software out | Page 4 | SatelliteGuys.US
holy crap they are pumping out updates
how about one for BL_ND SC_N
uh Pat, I'd like to buy a vowel...an A please :)
I dunno about BLind Scanning.
I have a couple Dummy Sats setup with 102 TPs all the Same Scan Rate - Poorman's Blind Scan
The DVB-S2 Dummy Sat take about 15 minutes to Scan, and the Pilot and FEC are fixed.
loaded the newest last night and have to start playing with it but didnt notice anything different
maybe they're all subtle changes
well dont like newest
when you hit "power" it says
10 (counts to 0)
SLEEP
SHUTDOWN
Sleep must be what we're use to but shutdown must mean "unplug box or turn off switch dummy"
also sometimes when I say "sleep" and try and power back on, there is a HDMI handshake issue....sometimes wont send signal to HDTV
this is version 4075...going to try 4056
update: when you press power and get that screen, pressing OK right away turns it off (sleep mode).....still dont like that. If you let it go to 0 the box does shut off
OK tried 4056
couple things I like when recording
-press "record" and it records. No stupid pop up with the time right now and end time 2 hours from now and then you have to hit "OK" to record. It records and below the info bar it shows the channel and how far recording
0:00:00-2:00:00 and it counts up (and down)
-you can hit record to fine tune the time...good part is you can go negative. So if its only a 1 hour program, hit record a second time to bring up the popup then where you would "extend" the recording, hit left arrow to shorten it. It shows -10,-20 etc
10 (counts to 0)
SLEEP
SHUTDOWN
OK tried 4056
Interesting! And weird, too. I currently have image 4001 installed, so I will mark your information when I upgrade to these versions and beware of these items.
Thanks ICE,
RADAR
Now maybe they werent enough high bitrate but I did record some HD with no issues. They were 5-6 minute recordings but they were stable
stations were (all off 121W)
RFDTV
Jewelry TV
STO HD
When I recorded other HD feeds in the past they were all herky jerky spazzy.
Can someone check the bitrate of those 3 if they have the capability to?
Actually, it's a good thing that the shutdown option is there. To avoid possible file system corruption make sure your box is off, not asleep, as data may still be in cache memory and not written to disk. Shutting down avoids the possibility of data loss.
I'm pretty sure Linux filesystems can be set up to not cache data. Whether the AZbox does so is another story. (Maybe it's not possible to do so at the bit rate required for HD, who knows?) I think it's the "sync" option, if anyone wants to check their mount flags.
On Rick's board, a user says that the latest daily build has blind scan. Anybody tried it yet?
When Blindscanning Are New Tp's Automatically Scanned in?
Deleting Multiple Channels Versus Single Channels
