Network card | SatelliteGuys.US
Network card
satsol67
33
Are the network cards enabled on the HR20's and if so can you do sharing on your home network?
Ethernet port is enabled, networking is enabled. You'll need to be either hard wired to your router or using a Wireless Access point that's wired into the HR20
Marty,
Have they had any luck with the Buffalo network drives comunicating with the HR-20's? Like the ones that are Microsoft "Plays for sure" Brand. I know Media player 11 works but I would like to be able to just go off the network drive if possible.
Thank you for the responce. Now if they would enable the USB on the R15's I would be happy.
Ron
new user - help with Tivo vs. their DVR
Adding HD locals, will they move me to a new plan?
