Ok, I got out the ladder and went up and looked- it says "Digital LNBF BS101UP201M lot No.E07" I don't see "DP" visible anywhere on the outside of it.Does the LNb have a DP on it, or is there no large print or engravings at all?
if a technician does come out he would replace your dish with a non legacy one,
Dish will be ditching the 322's and anything with a coax out soon as well.
Are you so "weary" you can't think straight, or are you so "wary" that you job might be in jeopardy? If you search through posts you will find the 322 has been discontinued for new installs. But the 311K bastardized version of this receiver is available and should offer UHF.Just be weary and ask the tech if they are paid per hour first instead of
Proof??? Link???
You DO realize that except for the Ho's/Jo's & 211k's, ALL other of their current HD receivers DO have coax outs...nor have they even talked about stopping those type of HD receiver installs.
Yes, thanks f/catching, fixed itI'm sure you meant the 211Z because the 211K has channel 3/4 out.
Agree, but considering their still installing (& refurbing) 722's, 612's, etc. & STILL installing SD only receivers on WA to this day, it's going to (much) later than sooner!To the point, it probably won't be for a few or even several years but as the older receivers get old and are phased out the coax output will go away. They've already stopped the 222K installs directly unless you can get one from a local dealer. As further proof, Dish hasn't manufactured anything other that Ho/Jo's and 211Z's for quite a while.
Limited time offer
