need RCA help | SatelliteGuys.US
need RCA help
perkunas
36
Ontario Canada
I got two boxes Openbox X5 and a Skybox F5S
Anyway I want to get the RCA plugs working, as this is going into an older TV.
best I can tell you need to set it to
Video resolution ...480i (I read some place that's the max for RCA)
Aspect Mode ...Auto
Video out...RGB (RGB YUV option)
Digital mode not sure here (YUV, BS Out, LPCM)
I think its BS not sure
But its still not working.....
Please help
The way you have it set up it should work. Just a note the Digital Audio out modes have no effect on composite out. That is only used if using HDMI.
Yep, but with an older TV you would not really benefit from having higher resolution as the old set is limited.
replacement for cable runs?
The FTA subject makes an appearance in Slashdot
