Time for some "shotgun" pruning i think. Theres one branch right in the way
Funny how a branch can stop a tp and others work. Odd
be a man and take down the whole tree!
Have they then completely turned off AMC 1 or it still active on 103.°0W?
source: http://space.io9.com/where-do-satellites-go-to-die-1572821932 / Where Do Satellites Go To Die?For geostationary satellites, it requires a big burst of fuel to deorbit and crash back to Earth, roughly 1,500 meters per second. In contrast, boosting that same satellite up to the graveyard orbit only takes a change of velocity of 11 meters per second. Alas, a satellite needs to do more than go fast to make it to the satellite graveyard — changing orbits also requires functional attitude controls, which not every aging satellite can pull off with grace.
By now, it's standard practice to retire old satellites in stable storage orbits 300 kilometers above the functional high geosynchronous orbits. It's a retirement home for elderly spacecraft, where they can admire the view and shuffle around peacefully without constantly having young whippersnapper satellites dodging around them. Best of all, it has a nice, healthy buffer between it and the functional satellites, so even if a retired satellite gets a bit wonky in its orbit, it won't go staggering into active traffic without warning.
Just rescanned 103w and not much of a difference. The beach cams still come in at 74% and NBC/Cozi bounces from 0 to 55%.
Kind've a bummer
Have you changed the skew on your ku lnb?
Is this like hoping it works now, just you will be doing it while on the roof?I'll hope on the roof
Is this like hoping it works now, just you will be doing it while on the roof?![]()
Limited time offer
