dcbag SatelliteGuys Pro Original poster Dec 17, 2003 249 0 Tennessee Jul 26, 2006 #1 Considering switching from D to E, limited sight to some satellites, can someone tell me location of Satellite Dish uses for Nashville HD locals?
RobbinM SatelliteGuys Pro Sep 7, 2003 192 0 Jul 26, 2006 #2 According to the Echostar Knowledge Base, Nashville HD is at 129. http://ekb.dbstalk.com/dishlist.htm
Poke Pub Member / Supporter Dec 3, 2003 13,886 238 OK Jul 27, 2006 #3 Like he said they are on the 129 Sat.. ABC CBS NBC Fox 6340 6341 6342 6343 here are the channels.. Get the hole list of Locals In HD that Dish has here.. http://ekb.dbstalk.com/hdlocal.htm
dcbag SatelliteGuys Pro Original poster Dec 17, 2003 249 0 Tennessee Jul 28, 2006 #4 Thanks for info. That takes care of the E issue for me. 129 is totally out of the question for me.
lakebum431 Pub Member / Supporter Pub Member / Supporter Lifetime Supporter Sep 5, 2005 17,145 5,116 Norris, TN Jul 28, 2006 #5 Are you sure? If you can get 110 and 119, 129 isn't that far away. If you are really interested in changing I suggest you get an installer to at least take a look.
Poke Pub Member / Supporter Dec 3, 2003 13,886 238 OK Jul 28, 2006 #6 I know some folks have issues with the 129. But if your installer install things the right way you should get a good singal from the 129..
