I can just about get tversity to stream any format in 720 at this point. You just have to fool with the settings. I have always transcode selected as well as the pro version. I think I remember reading somewhere in a side by side comparison that the free version didn't transcode h264 and possibly others. I also have a hic in line behind my hopper. Laptop is also hardwired into my router.
I got tversity working but it only does 2-channel audio. My favorite so far that has done and played everything (including ac3 5.1) is Mezzmo. I like the look of Plex, but I just couldn't get it configured to my liking yet.
Thanks for the tip.
I was struggling with Serviio as well. It would see the server, but it would never load any media files. I tried all of the different profiles without luck.
I just downloaded the Mezzmo trial, it's 30$ to buy, and it worked like a rockstar. Without any config, the Hopper was able to see my Mezzmo service, and all my movie files (encoded by Handbrake using AppleTV/AppleTV2 format), it's streaming Goonies right now. My audio decoder is showing Dobly Digital, so it's passing the audio in the right format as well (no crappy 2 channel stuff here).
So in summary.
Get the HIC, you need that for your Hopper and All Joey's to be able to grab IP addresses.
Get Mezzmo, it seems to be the best product so far.
That's all for now gang! Enjoy!
dtrose said:I just loaded Mezzmo as well but have no controls on the Hopper (like Fast Forward / Rewind) except for Pause and Stop. Is this a limitation of the Hopper or Mezzmo.
rhambus said:This thread has been so helpful - thanks, all (first time poster here). I have a 1H/1J system and would like to get DLNA working on the Joey. I have it directly connected to an ethernet cable and it's detecting both TVersity (which I want to use) and my Windows Home Server 2011. I can browse folders and whatnot as well without any problems. But when I try to actually play a program, nothing happens. Hitting select does nothing, hitting play does nothing. I have TVersity set to always transcode and it works just fine with my Xbox 360, but the Joey simply will not play any of the programs I have (I believe they are Divx/Xvid format AVIs). Any ideas?
rhambus said:Will a HIC help? It seems like since I can already see the files but not play them, connectivity is not the issue. Did someone else have this problem that I am having? I didn't see any sign of it in the thread.
Luv2K155 said:I'm repeating this post here...
Dish Network rolled out an update a couple of days ago and Home Media is working.
Those of you using other software may wish to look at PS3 Media Server. I've tested about every DLNA compliant server out there and have found it to be the best. It's freeware and you don't have to have a PS3 to use it. PS3 Media Server is fast, does not put a huge load on your processor and does not build a huge database every time you open it or add files to the directories you are sharing. Best of all there are both Windows and Linux versions of the program.
From what I can tell, it looks like the Hopper can't read a lot of file formats. It doesn't seem to like .avi unless the video has been encoded in mp4 format. My guess is that Dish Network hasn't negotiated a license with DIVX, Microsoft, or Apple yet and has never heard of XVID.
Anyway, you may need to convert your video files in .mp4 format. If you do, there are two freeware applications you can use. The first is HandBrake and the second one is called Freemake Video Converter, both are freeware. They can be found on FileHippo.com and MajorGeeks.com.
Freemake Video Converter supports a lot of file formats, will natively do batch conversions of files but, only runs under Windows... unless you can figure out how to get .NET 4.0 installed in Linux that is.
HandBrake has a Linux version and will also do batch conversion of files but, will take a lot of mouse clicks to do so. There is a Windows version and someone has created a utility called "HandBrake Encoder v1.0" to fix that problem under Windows; however, I haven't used it yet. Again, if you can get .NET 4.0 to install you can try and use the Windows version under Linux for easier batch processing of files.
I recommend Windows users stick with Freemake Video Converter and Linux users the Linux version of HandBrake. Hope this helps.
Limited time offer
