My Harmony SST-659 Remote is not learning the 811's remote | SatelliteGuys.US
HDTV Rookie
173
Texas
I recently purchased a Harmony SST-659 remote and when I try to fire off the commands from the 811's remote, they do not register with the Harmony remote. Has anyone else tried to program any learning remotes or found a work around. I believe the issue is b/c the 811 remote is UHF based and not IR based
The remote that comes with the 811 does not emit IR codes for the 811, only UHF. You can use a 6000 or 5000 remote to program your universal remote. Other Dish remotes may also work, such as the 721 remote.
I tried using my 508 remote, but it didn't work
hmm, I may have to redo that, because I have my 508 remote on channel 1 and 811 on channel 3.
I might have to change 508 to channel 3 then try
duh, should have thought of it
Thx, anyway
Harmony have the 811 in their database. Perhaps you can get by without needing to learn the remote?
Keith.
Keith
you are correct, they do have the 811 in their database, but for mainly the basic features. I was looking to learn the page up and down buttons, as well as skip forward and back, and finally aspect.
When I setup my Harmony, one of the CSR for Harmony told me the 811 was there, but when I called later that day b/c I didn't see itin the database another CSR told me he didn't see it. So I gave him some info and he hooked me up with that setup.
HDTV Rookie said:
Keith
had similar probelm with the 921 remote. I ended up using a 501 remote info. It does the page up\down correctly.
522 on dish site, but....
Is the 921 as stupid as the 721?
