Multiswitch help... | SatelliteGuys.US
Multiswitch help...
jahnal
3
New Jersey
I just moved to NJ and my house have 3 runs from the directv dish. The first run is to the first floor to an H20 and the other 2 going to the second floor at a wall plate theen they get connected to STD boxes. Can I add a multiswitch at that point to add more TVs instead of running more cables and making more holes in the side of my house:(.
A multiswitch would have to have 4 runs from the Dish, then output to every location. You can't do what you mention.
You can install a multiswitch at the dish and then run an additional line to wherever you want to add a receiver though. It is common to install a M/S outdoors, they're weatherproof, as long as your cable connections are ;)
WELCOME to Satelliteguys!
JC would the new Driectv dish be the swn single wire lnb slimline and thank you for your help. last year a tech came to my house and it looked just like it.
Also note that if you go with an SWM installation all receivers will need to be SWM capable.
Good point, I forgot that.
You said you have STD receivers, I think you mean standard?
I don't believe any of the D series basic SD receivers are SWM compatible, someone correct me if I'm wrong.
In that case - you'd have to upgrade them all to H series or stay with a traditional multiswitch, in which case you'll have to do another wire.
Yeah everything has to be SWM ready.
Power Inserter location for SWM-LNB
LNB or Receiver problem?
