MRV broke on 1 of 2 HR22's | SatelliteGuys.US
dslate69
782
NC
Ok got the latest CE on Friday night. Now one of my HR22's stopped seeing the other with MRV.
Upstairs sees Downstairs and can play content.
Downstairs goes straight to its own playlist.
mrvclienton entered on both boxes and *edgecutter* entered so I see MRV is set to On in both menus. I guess my problem lies on the box Upstairs?
Help needed on this one.
How is it hooked up? Do you have it hard-wired or wireless? If it is wireless. have you tried unplugging your router and plugging it back in?
Reboot your upstairs receiver. Did you report the problem in the CE thread and send a report? That greatly helps DirecTv.
Thanks and no. I figured it was something easy or the classic reboot.
I will try mrvclientoff like stuart628 (thanks) suggested first.
Knee deep in some modding tonight though.
Thanks again.
Well like the great troubleshooter I am I ended up doing the mrvclientoff, mrvclienton, *edgecutter, and then rebooted last night then went to sleep. This morning it was working. So I guess all suggestions worked. ;)
Thanks for the help.
HR2x / R22 CE Release 5/15 v.0310
CE Release for H20 5/22 v.4122
