Moving | SatelliteGuys.US
Moving
Alvarez
364
Brownsburg, IN
I will be moving in about a month and a half... I would rather a professional install and I know you can call DirectV and arrange for them to come out and install your stuff but I ran into a bunch of crap about them installing my OTA antenna or even leaving a Diplexer for me to run my OTA antenna myself.
Basically even though D* had agreed before my installation that the installer would install the 4 rooms and my current OTA antenna that was left behind by VOOM the installer said he had no order for it and I would have to pay him for it.
He called D* and the lady said nothing was written about them doing it.. I talked him into leaving a diplexer and I undid his install and ran the OTA antenna after he left. So my question is this... I am now moving and would like my OTA antenna hooked up and a professional install as this is a newer nice house.... How should I go about it and about how much in advance should I call them to book the install?
I just used the "Movers Connection" service and they were great!! I told the CSR that I had an antenna and to make sure she added the install to the order. They used a sattelite mount and stuck it up and wired it. They also used a 4 position ground block and tied it all the a water pipe. Very good job. Make sure you call the special mover connection number to set it up, 1-877-616-MOVE, instead of the normal number.
Thanks!!! We are really psyched up..
I contacted the movers connection and they said that they would hook up the OTA antenna but they WILL NOT hook up the 2 lines needed for a DVR because I don't currently have one...
I am thinkin about activating one of my old old receivers I have laying around and listing it as family room also so they will have to hook up 2 receivers... then I can hook the lines up to a DVR later.
That may be a lot easier than adding a wire later!!
WiFi device for wireless TV
Slow Guide on Direct TV Tivo
