Well, I have successfully moved to my state capital of Baton Rouge, Home of this years 2010 1A College Footballs National Champions
LSU FIGHTING TIGERS
GEAUX TIGERS.
p.s. I had a little trouble because the first CSR was a idiot but the next one was easy to work with.
LSU FIGHTING TIGERS
GEAUX TIGERS.
I moved to Dallas from Sport, like you I might have to move to BR for just LSU![]()
Well, I have successfully moved to my state capital of Baton Rouge.
Congratulations!
I don't mean to hijack the thread, and please someone tell me if I should start my own instead of jumping in to this one, but I live not far from you: north central Louisiana (Ruston). Like you, I have an antenna that pulls in the major networks decently well. Also like you, I would still like to acquire HD locals via DishNetwork.
My question to you is: now that you are pulling in HD locals from another DMA, has that messed up your guide info? In other words, do you still see the guide info for Monroe for your antenna as well as Baton Rouge for your new Dish HD locals? I like how Dish allows me to use the guide to automatically program recordings using the antenna, but if I lose guide data for Monroe, that would become more complicated.
I'm still trying to figure out the discrepancies between the transponder/spotbeam and the spotbeam number in the tables, as well as the ramifications of Digiblur's question about whether you have an SD receiver. (I have a 722 for HD and a 311 for SD.) However, I'm hoping to work those out soon; I'm excited about the possibility of getting HD locals from another DMA.
Thanks so much! I hope you are enjoying your new extra channels!
Congratulations!
Digiblur and Whatchel1:
Thanks for your kind responses. Digiblur: your explanation of SD vs. HD spotbeams was especially helpful. Many thanks!
It looks like I am out of luck. I get a signal strength of 43 on Sat 129, SB 03 for Fort Smith HD channels, but nothing for SD. I get a signal strength of about 26 for both Lafayette and Baton Rouge HDs (they share the same spotbeam but on different transponders), AND I get great signals for the transponders that should broadcast the SD channels; HOWEVER, the word "transponder" doesn't change to "spotbeam" for either Baton Rouge or Lafayette. I'm assuming this means that I must be out of range, even though I'm picking up strong signals for something.
I briefly thought about moving to Little Rock, since their SD channels are very strong here. Unfortunately, their HD channels are on Satellite 77. I think I need a wing antenna(?) to get these, and that would be hard to explain if I am "moving."
Again, thanks much for the information! This is a great site; I've learned a lot.
What signals do you get on TP 1-16 that lock and say spotbeam? Also check TP 20 and 21 for national signal strength reference.
For 77, you would need to find a Dish300 or Dish500 and put a dishpro LNB on it. You wouldn't have to explain much. Just tell them you have the Dish hooked up and ready to go.
On 110, none of the transponders from 1-16 switch from "transponder" to "spotbeam", though I get good signals (upper 60s to low 70s) on all of them. TP 20 does switch to "spotbeam" (Memphis?), but doesn't lock at a signal strength of 7. TP 21 comes in at around 70.
I forgot that I have an old dish still on the roof that was installed back in 2004. Because of tree growth in nearby yards, it wasn't getting great signals even before I upgraded to HD and got a new antenna (located several feet over and a little higher) along with a new receiver. It probably is a 300, but I'll have to look.
Thanks!
I was asking about 129. You never know...you could point it at 77 and tie into the Dish1000 and be ready to do whatever you want.
Limited time offer
