P Pinkfloyd SatelliteGuys Family Original poster Jul 24, 2004 53 0 Oct 25, 2006 #1 Is it possible to "Move" to atlanta in order to get the CW in HD from CT? Or is that out of the Spot beam? Thanks!
D dishrich SatelliteGuys Pro Sep 8, 2003 3,420 569 Springfield, IL Oct 25, 2006 #2 It's WAY out of the spot beam... (I assume you meant Atlanta, GA)
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,441 15,076 Mankato, MN Oct 25, 2006 #3 on DirecTV almost all locals are on spot beams so no you wouldn't be able to get it
P Pinkfloyd SatelliteGuys Family Original poster Jul 24, 2004 53 0 Oct 25, 2006 #4 Thanks, Thought I'd try! .. Cant get it OTA here..
Questioner SatelliteGuys Pro Mar 27, 2006 855 0 Oct 25, 2006 #5 I wouldn't say it's "way" out of range as one might think, but still too far I'm pretty sure.
P Pinkfloyd SatelliteGuys Family Original poster Jul 24, 2004 53 0 Oct 25, 2006 #7 bonscott87 said: There's always Bittorrent. Click to expand... They have HD versions of Smallville on it?? I missed the Season Premier
