It has to connect to where the D* splitter is located now.I'm moving a Mini to a different room can I use a splitter or do I need to run it outside to the swim switch. The cable that goes to this room meets up with where the cable going to a mini is.
Can I use a splitter? It had to have been plugged into one in the room it was in since there are only 3 coming from the swim switch but I've always had 4 boxesIt has to connect to where the D* splitter is located now.
I was presuming it was a SWM splitter .... knowing for sure the set up will clarify things.Do you have a swm switch or a swm splitter? How many lines come from the dish?
I have one line from the dish to the swim of sorts I assume it's a switch that has 4 ports. 3 of which are being used but I have 1 genie and 3 minis so I know there is a splitter somewhere I just haven't found it. But I am moving one of the minis to a different room that is next to one that has a mini in it and the coax from this new room meets up with where a barrel connector is for the other room.Do you have a swm switch or a swm splitter? How many lines come from the dish?
Hr44-500. And yes I have a power inserterWhat you are calling a switch is really a splitter. There is one cable from the dish to the splitter, then cables to each mini and the Genie. Do you have a separate power inserter? Which model Genie? As long as the cable you connect the mini to goes back to the splitter you should be fine.
Thanks claude I'll go online and find one that's DirecTV approvedYou could use a regular splitter as I believe the client is running on a 500 or 600 MHz signal.
However I would use the Directv approved stuff to be safe
This line does not meet the others at the splitter it meets with one that has a barrel connector that goes to a different miniWhy do you need another splitter?
I assumed it was possible because I have 3 minis and of course the genie but only 3 coax comes from the splitter outside so I know it is getting split atleast once insideI'm not sure if you can split a line to a mini like that. Installers?
You'll be surprised how many splitters you can chain with Directv.
I see Directv installers convert dish installs. Those are the worse with the number of 2 way splitters being used.
All diplexers get changed to splitters.
Got a DirecTV approved splitter yesterday and all works great! Thanks guysYou'll be surprised how many splitters you can chain with Directv.
Yeah one time for the hell of it I chained something like 4 2 way, 1 3 way and 1 4 way off an 8 way that was connected directly to a SWM16 output, and the H20 on the end of that still had picture. The 8 way was a SWM splitter, all the rest were just ordinary cable or satellite splitters, and there was probably around 30' of coax total as well.
There's a lot of slop in Directv's specs, receivers can receive a signal WAY weaker than the -55 dbm that I believe Directv specs. I don't have a meter or anything, but I had to be below -70 dbm at that point. Of course "worked for a minute when I tried it" isn't the same as rock solid 24x7 for everyone who tries it so their generous specs are understandable.
Limited time offer
