Move access card between receivers? | SatelliteGuys.US
eric01887
3
MA, USA
Okay I'm sure this is a dumb question but surprisingly didn't find an answer on Google...
I've got a Sony SAT-A55 (yes an antique!) that's been working fine for years until a few days ago when it croaked. Signal strength reads "0" no matter which transponder I choose.
Went to my "shelf full of DirecTV junk" and grabbed a SAT-B55, hooked it up, it gets a signal just fine.
So now my question (finally): I know from trying I can't just pull the access card out of the A55 and put it in the B55... do I need to do the "new access card" thing on the B55, or do I need to call D* or what? Are they going to make me buy a new card?
If your A55 has a reciever ID yes you need a new card but it very old so i doubt it.
If your reciever does not have a reciever id you should be able to put it in another reciever with out cause.
But if the 2nd reciever has a rid the access card will marry with the rid so pick your boxes wisely
If your new receiver does NOT have a receiver ID (which I don't think EITHER of yours do), then just simply put the card into the new receiver, call up D* customer service & after you put in your phone#, just punch in "721" & this will send out an automated rehit to all your reciever(s) on the account, which will also remarry this card to the new receiver - no CSR intervention needed.
Well "no CSR intervention" is always good! :D
These receivers are ancient - close to 10 years old so I'm 99% sure they don't have RID.
I'll try the "721" thing... thanks!
Hr23 Pricing Question????
Help getting Sat 99 and 103
