mounting pole | SatelliteGuys.US
mounting pole
hotshot12345
30
WA, USA
I understand that it has to be plumb. My question is is there a difference between adjusting the plumb with vs without the dish attached. The reason I asked is I initially mounted the pole plumb without the dish. Now I just had to adjust the pole but I left the dish attached to the pole.
Thanks.
Sometimes the dish, especially when attached to a motor, will pull the pole slightly due to the weight. Ideally, you want the pole to be plumb with the dish and motor (if applicable) attached. If there is no motor, a perfectly plumb pole is not as crucial, as adjustments may be made to dish azimuth and elevation to correct for the pole. With a motorized system, this is not possible, as the dish must track the entire arc of satellites across the sky perfectly. Therefore, on a motorized setup, you want the pole (and more importantly the motor and motor bracket) to be absolutely level when everything is attached.
mount the pole plumb....aim the dish/motor....then check it again....it obviously needs to be plumb after the installation is complete....
one thing to remember is....its the motor bracket that needs to be level....not the pole itself....
use a small level and make sure your motors bracket is level after you snug all the bolts....if it is not level then you need to adjust the mounting pole until the motors bracket is level....
edit....just saw tron said the same thing....lol
Best DiSEqC switch for more than 4 Satellite
Is 36" Channel Master Good Enough For LPBS on 125w?
