Yes .How about connected to the Internet?
Is the Joey 3 and Hopper 3 in bridged mode?I was wrong I checked on the joey 3 connected to the Hopper in my house and it doesn't show up. But it is on the Hopper 3 under all sub. My Buddy has his blocked for some reason in his locks menu. I will change that when I go over there next time. He doesn't use You tube so I think he must of blocked it to clear out his guide of clutter he doesn't use. I guess the joey 3 doesn't get access to You tube by design.
Yes I think. I wouldn't get internet for other apps if it wasn't right? I checked and I can see Netflix over the joey and Prime comes in over the joey too. I also checked the other joey 3 in the bedroom and it also has no You tube.Is the Joey 3 and Hopper 3 in bridged mode?
It was because that is the list I use on my guide. I think something happened with the 341 update.Should be made available in a Favorites List, IMO.
Correct, the Joeys do not get YouTube, only the hopper.I was wrong I checked on the joey 3 connected to the Hopper in my house and it doesn't show up. But it is on the Hopper 3 under all sub. My Buddy has his blocked for some reason in his locks menu. I will change that when I go over there next time. He doesn't use You tube so I think he must of blocked it to clear out his guide of clutter he doesn't use. I guess the joey 3 doesn't get access to You tube by design.
Yep, We used to access it that way.It was because that is the list I use on my guide. I think something happened with the 341 update.
Joey 3's have YT, don't they?Correct, the Joeys do not get YouTube, only the hopper.
Nope, not on the 4K Joey either.Joey 3's have YT, don't they?
I knew about the 4K, but I thought the J3 did. Oh wellNope, not on the 4K Joey either.
no, they get amazon prime. It took me a long to remember it was prime and not YouTube.Joey 3's have YT, don't they?
It gets even more confusing then that. No Joey's run YouTube, and Joey's able to run Netflix/Amazon Prime (1/2/3/4k or 3/4k respectively) only do so if connected to a Hopper also capable of such apps. So a Joey3 on a Hopper2000 wont have access to either app (unlikely scenario) and a Joey3 connected to a Duo wont have access to Prime (far more likely scenario). I'm pretty sure that if you could connect a Joey4 series receiver to either of these Hoppers they would work fine, but Dish wont allow that setup.no, they get amazon prime. It took me a long to remember it was prime and not YouTube.
The Joey 4 will have this, but it is the only one.Correct, the Joeys do not get YouTube, only the hopper.
Limited time offer
