Missing Channels | SatelliteGuys.US
Missing Channels
bill-bill
8
How come on my DirecTV I don't have FX, TVOne, FitTV, FSN, etc… does channels appeal to be missing, what is the problem, and what do I need to do to get those channels back?
Pobably just a simple reset of your box is needed. D* has been moving some transponders around and may have affected you.
Unplug wait 15 secs and then plug in.
thanks, it work
This is STILL going on? I thought this had ended. Is it still only happening to Thompson products? One would think that if it was a transponder issue that all IRD's would be affected.
I lost channels on both my Thompson in the den, and my HDTivo. Channels were unchecked in my Favs on the Tivo. Checked them again, everything was fine. Rebooted the Thompson, and Fittv was missing from the channel list. Punched the channel # fitTv came up, scrolled thru channels, and FitTv was still there but it was still missing from the channel list. Checked tonight and its back on the channel list. Thats weird.
Is D* using Harmonic Encoders?
DIRECTV & CABLE INTERNET
