I like it but it wont work with my Dish and Motor.
When I turn on Motorized Dish I can't get a signal from the dish. Turn off Motorized Dish and signal comes through fine.
Part of the issue could be the DISEQ Swtch built into my LNB, so I ordered a WS741 LNB which uses 22 Khz switching instead. Hopefully this fixes my issue.
(BTW I should note to move my dish I am using a GBOX controller.)
latest firmware for the s10 fixed the clock, s9 clock is still broken, they say its a hardware problem, but i dont know.
i am still hoping for manual pid input without having to use the editor, but the latest firmware seems VERY good for these boxes (with the exception of the clock on the s9 and no manual pid input on both)
Good luck scott! The 741 can be abit tricky to set up correctly but when it is! both c and ku should work very well for you.I like it but it wont work with my Dish and Motor.
my s9 does fine with a 16 gb flash drive
are you talking about a platter type usb drive?
Yes, external powered HDD. Try it. Then try and turn it off, then back on etc...You have to unhook the drive to turn it off etc.
Hey Stone, does it work good with the HDD? Can a S9 play the files?
BTW if there is enough interest in this receiver I would be happy to open a Manhattan forum just like we did for the AZbox.
Limited time offer
