Lyngsat Lite | SatelliteGuys.US
Lyngsat Lite
kymics
208
Winnipeg, Manitoba
I got this cool program SnagIt installed on my work PC today, so I was putting it through its paces. I decided to created my personal view of Lyngsat's chart for what's really available to me as a Ku user here in Southern Manitoba.. talk about shrinkage :p
Just curious, what's the difference between using that software and just hitting alt / print screen on the keyboard and pasting it in any photo editing software?
That's the way I used to do my captures. SnagIt lets you grab it and edit all at once. It also has a scrolling capture so if the screenshot is too big it will scroll and capture the whole page. From there you can just drag to trim the capture to the right size.
As you can see with this particular capture, these coordinates don't all show up together on the Lyngsat screen, so I grabbed and moved them to line up sequentially. Real easy.
Equipment suggestions
Having some setup issues
