When I was in Korea, our Service Battery had a sign painted that said, "if you can't fix it, get a bigger hammer"A BIGGER hammer.
I hate to ask the obvious but....129 is the lowest in the sky. Any trees grow a little higher this year?I agree that it is strange that the problem follows 129. The cabling was replaced when the dish was moved to the roof last fall. On Thursday he changed the switch connections so 119 = Port 1 110= Port 2 and 129= Port 3.
Since 129 has always had the lowest signal would that cause 129 to be the one dropped? They were supposed to send an Advanced Tech but I have been getting normal techs. I would think they could check the impedance of the cabling. Also check for grounding issues.
Same here, my rate of NPF is 0% and has been for a long time. If there's a way to fix it, I'm gonna fix it, or if it's out of my abilities, advise the customer on the best way to fix it
I think for internals, NPF's is one of their Pi metrics
Replacing that is an encouraging sign.but the cable going through the wall was the original from 2000.
Hopefully this will end my problems.
Limited time offer
