local spot beam channels from close city | SatelliteGuys.US
Kali05
SatelliteGuys Guru
142
7
Ca
i was wondering if this is possible since i live 4 hours away to the west to get san francisco local channels zip code is 94108... and mine is visalia/tulare locals 93274 zip code i really dont understand the map sattilte boundries from me if their anyone out their that can tell me if it possible to get san francisco locals in my area when i provide with a local adress any help would be appreaited thanks i do have dish 500 im looking for sd channels
I assume that you get sat 119.
If so, hit menu - 6 - 1 - 1 point dish screen, check satellite 119, transponder 7. If it shows spotbeam 4 and you have a decent signal, you're golden.
well i did that and no signal doea that mean i dont get it? i do get aon the transponder spot a spot beam 5 ,3, 1
i do get a message spotbeam on 26 transponder signal is 26 percent and on transponder 31 no signal strength
HD size on 622?
Western Arc Install in FL? Am I going to lose any channels...
