LNB Change over | SatelliteGuys.US
LNB Change over
JackR
17
I have the new Invacom QPH-031 LNB that I plan on replacing the Invacom
SNH-031 with. Should I do a reset before changing or just plan on changing the setting for each satellite, one at a time? Any other pit falls I should look out for?
Jack
Just remember to set the L.O. to 11250 for the Circular side and 10750 for the linear side!
amc 3 pbs stations
Rotor Help
