Lip sync problems on UHD. | SatelliteGuys.US
markd
287
Memphis area
Is anyone else having problems with lip sync on UHD on DirecTV. It's the only channel I notice it on.
I have the HR-21 hooked up to my Onyko SR805. I have the last public firmware (no CE).
Mark
Mark
You can adjust the Onkyo for sync but I wouldn't do it for just one channel. I had a problem with CBS and made the adjustment and all channels have been good since then. If you need more info go to the AVS forum for receivers, lots of knowledgeable people there using Onkyos.
Thank joed32.
I might do a little more tweaking on it. I've already tweaked it for the other channels. Maybe tweaking just a little bit will help and not hinder the other channels.
Splitting an OTA feed
No Signal Strength On Odd Transponders for Sat A(101)
